Visa Control Customized with System look
Hello, I would like to have the Visa Ressource Name Control with the same look as a System Ring. See on attached file what I mean. I'm not sure how to work with the Customization tool, i need some tips.
Is there any library on the web with custom controls, and xcontrols?
Jimmy
(4,193 Views)
I take always aCombo Box from the System Controls Palette instead of VISA Control. You can fill the Combo Box before use with Strings[] Property and Find VISA Ressource.
(4,175 Views)
Accepted by topic author JICHFI
Would the .ctl I attached in this post work for you?
XP Style NI-VISA Control
(4,165 Views)
Thank you very much Phillip, that's even better than what I expected.
(4,152 Views)
