Visa Read - build a table
Hi dpk,
LabVIEW basics: how often will a FOR loop run with several autoindexing inputs?
Why do you expect "33", which is the 5th element, when there are only 4 row/column headers?
Message 11 of 14
(945 Views)
Hi
I got what you are saying. But I thought I should get something like the attached screenshot here. Suppose I have only 4 row/column headers, and I have 16 different values, I want to fill the table with those 16 different values. That's what my final goal is.
Message 12 of 14
(942 Views)
Accepted by topic author dpksmth
Here's one possible solution.
The issue is that your autoindexed array at the top has 4 values, and the bottom has more, and so the loop runs 4 times.
If you do some index manipulation like shown here (and in the labelling of indices for randomization in my earlier VI), then you can index the correct element each time, and not just get repeated values.
Edit: the same VI with autocleanup and some minor rearrangement. Posting alongside rather than replacing because probably easier to see differences when not the whole thing changes shape at once!
GCentral
Message 13 of 14
(938 Views)
Hi
Thank you very much for you all the time and efforts to help me. I really appreciate it.
All the best. and stay safe from COVID-19.
Message 14 of 14
(914 Views)
