Visa crashes with unknown error
I'm trying to get a Yokogawa WT310E power meter to work with Labview 2017 on windows 7. I've successfully installed the windows drivers and it appears in Device manager but not MAX ( https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019La2SAE&l=en-GB ). The first step is "Check if you have the NI-VISA driver installed on your computer", in doing so I; opened up the NI-Visa Driver Wizard, selected USB and the device with the identifier of the one i want to receive measurements from (checked from device manager), the details briefly load but almost immediately it crashes.
Clicking OK closes the window and Visa, does anyone know how i should proceed with this?
I've attached the full reports and dump files as well.
(2,805 Views)
Accepted by topic author geroge123
Reinstalled visa error no longer appears will open another topic to deal with no device in NI max
(2,768 Views)
