Visa doesn't work in runtime environement, but does in development?
I have a vi that utilizes visa for accessing a comport associated with a serial port.
The vi works just fine in the development environment, but after I compile it, the vi's no longer can access the com ports.
any special trick necessary during the compile to ensure that the visa still works?
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
(2,539 Views)
does this behaviour occurs on the same computer ?
V-F
(2,519 Views)
Accepted by topic author eximo
Problem solved, the runtime environment requires visa runtime drivers.  The developement environment requires different visa drivers.
My visa runtime environment drivers were out of date.
http://www.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du,n8:3.25.123.1640,ssna...
here are the visa driver updates for both environements
Happy hunting!
-Regards
eximo
Neuronetrix
(2,506 Views)
