Visa error in exe build
Hi all,
I’m having some difficulties with running an EXE file which returns the error “VISA Flush I/O Buffer in TSI 4000.lvlib:Initialize.vi->Flow v Pressure Test 2.vi” on the EXE file I created. The VI runs smoothly using full Labview 2016 on the same machine without unplugging any of the instruments.
I have been using the application debugger to compare the two different programs and have identified an issue with the Visa registration as follows:
From probe 19 placed on the EXE file there is some missing Visa information (C.F. Figure 1 and 2 for probe comparison).
Figure 1: Output from probe 19 (exe file). (please see attached Picture files)
Figure 2: Output from probe 18 positioned at the same location as probe 19 (.VI file).
I have tried including the visa information in the build using “Method 1: Including the NI MAX Hardware Configuration” described here: http://digital.ni.com/public.nsf/allkb/80F2165E774B51FB86257CAC006E81A9
But this didn’t seem to work.
Instruments cluster as indicated in figure 1
Further information:
Figure 3: Front panel visa information (EXE and .VI are the same)
FYI, this is a program which was written by somebody who has recently left the company so although I have gone through the program I may have missed something simple.
Thanks for your help.
Message 1 of 1
(2,632 Views)
