Visa problem with leopard (OS X 10.5)
Hi
I want to use Labview 8.2 student edition with leopard. I want to use visa to
read data from an usb-rs232 dongle. The problem ist I can't configure visa.
Everytime I run "NI-VISA configuration" I get the error:
Connot launch Java application
Uncaught exception in main method:
java.lang.UnsatisfiedLinkError: /Applications/National Instruments/NI-VISA/NI-VISA Configuration.app/Contents/Resources/Java/libVisaEnetConfig.jnilib:
I did a fresh installation of leopard and labview.
I tested another java application and it is running. So I don't think this is related to the java VM.
Any idea what is wrong?
(2,830 Views)
As far as I can remember the student edition is quite limited and can not communicate with any device (it may have changed), check this on NI website 😉
Have you been able to communicate through VISA with a device with another version of OS X and LabVIEW student edition Smiley Surprised ?
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,829 Views)
It worked with Tiger.
I think I found one problem. Using a current visa version (4.2) solves this problem.
Now Labview crashes when I do a masscompile but this is another problem.
(2,822 Views)
