Visa read error -1073807313
I get a Visa read error occasionally with the above error number. Any ideas on why it is happening?
(5,480 Views)
The error description is:
"VISA: (Hex 0xBFFF002F) You must be enabled for events of the specified type in order to receive them."
What function is returning this error?.
DiegoF
National Instruments.
(5,480 Views)
Read Visa vi.
(5,480 Views)
Can you taka a spy capture and attach it to you post. Check the follwing tutorial on NI-Spy:
NI-SPY Tutorial
You can enable logging in the Spy menu >> Options.
DiegoF
National instruments.
(5,480 Views)
Was this resolved? I am having the same problem when I repeatedly read/write to an RS232 port.
(4,794 Views)
I'm getting the same error sporadically from a VISA Read.  Any ideas?
Robert Mortensen
CLA, CLED, LabVIEW Champion, Principal Systems Engineer, Testeract
(4,606 Views)
