Visa read
I'm trying my best to use VISA lately with 7.1, rather than reverting back to the trusty old Serial vi's. I'm hitting some snags - things that worked before might nort work now. Please view the attached screen shot. This is how I am reading the com port. On occasion, I get a framming error, but now always. I've checked the normal stufff - parity, stop bits, baud rate, etc. Is there anything inherently wrong with what I'm doing here? Would you do it differently?
note: the "1RPA0" is the command for the serial device to check a digital input. Elsewhere in the program, there are lots of serial writes but no other reads.
Richard
(3,788 Views)
I would put the VISA read in a case structure, and only execute it if the Bytes At Port was greater than 0. Better yet, create a loop to read Bytes At Port and exit the loop only when Bytes is greater than 0 or some timeout value. Then read VISA if loop has not exited due to timeout (bytes > 0). Put a timer in your loop to allow time for all bytes to be recieved to get to the port.
- tbob
Inventor of the WORM Global
(3,788 Views)
Thanks. While your suggestions didn't fix the problem, they did remind me to make sure I have bytes before I read them. Now I can check for comm failures.
What DID seem to work was adding a Flush Buffer function before I do the write/read.
I have attached the fix. Does this make sense? Why did the old serial vi's work fine every time, whereas the VISA function require more code?
Richard
(3,788 Views)
forgot attachement
Richard
(3,788 Views)
My guess is that your serial port had received garbage characters before the Visa read was done, possibly corrupting your read with a framing error. By flushing, you get rid of those extra characters. Don't know why the old serial read worked whereas the Visa read needed flushing beforehand.
- tbob
(3,788 Views)
Me neither. Maybe bacuase I didn't use the error handlers in the old VI's, I was getting garbage, or hiccups, and not realizing it. The VISA stuff forces the issue in reagrds to errors.
It's working fine now. Thanks tbob
Richard
(3,788 Views)
