Visa reading different command from my pressure transducer
Hi All,
I'm new to Labview programming, and want your feedback. The issue is, when I write a command for visa to read and write, it reads the wrong command. Sometimes it reads the correct command, then swaps and reads a different command. I have two paroscientific pressure transducers, and both are
controlled by serial ASCII command. The command *0100P3, reads the pressure, and *0100Q3, reads the temperature. I have attached a labview file (2010 32 bit) and would like some feedback.
Newlab
(2,441 Views)
Your Serial VISA read write subVI is missing. So I don't know exactly what you have going on in there.
But I think your problem is that the subVI's are running in parallel.  You have a race condition as to which of the subVI's are running first.
Also, are you getting any error messages?  You do not have your error wires wired up on those subVI's.
(2,434 Views)
