Visa test panel works, yet visa write vi does not
Hello all, this is my first post hereSmiley Happy
I'm trying to communicate with a piezo controller instrument using my serial port.  I can successfully write a command using the visa test panel, 'AV20\r' for example sets all the voltage channels to 20 volts.  In my labview vi, I configure the serial port with the same settings I see in the test panel and run it, yet the instrument doesn't respond.
Any suggestions would be greatly appreciated, I'm sure I must be missing something simple here...
Brian
(2,739 Views)
Accepted by topic author BPile
Are you sure your string constant or control in LabVIEW that contains the string is setup to show \codes mode?
(2,738 Views)
Thanks RavensFan! That did the trick.  Just so I understand what was happening...I was sending the text string \r rather than the hexadecimal representation of the carriage return?
(2,732 Views)
Exactly! Smiley Happy
(2,723 Views)
