Viserver as executable
i will try to use the example http://zone.ni.com/devzone/cda/epd/p/id/4410 .
Both the Server and the Client must be an executable.
What must I do to make it running?
I am using LV10.
Excuse my bad english.
Thank you
Ralph
(2,826 Views)
You need to start by creating the executables. Have you done this? Do you know how to create executables? If not, please check the LabVIEW documentation, as it explains how to create executables. You can also read this: https://www.ni.com/en/support/documentation/supplemental/19/introduction-to-the-labview-application-...
(2,805 Views)
