05-12-2006 08:50 AM
05-12-2006 09:24 AM
05-15-2006 11:01 AM
05-15-2006 11:22 AM
I suppose it's possible that the example names have changed with LabVIEW 8 but you should still be able to find something. In the example finder, do you have a topic called Building User Interfaces>Designing Dialog Boxes? Did you do a search for pop-up or dialog?
I don't understand what exactly you mean by "create a property node and set it's visiblilty". Property nodes are on the diagram and there is no way to hide objects on the diagram nor do I see why you would want to make the diagram visible. From what I understood you need to do, you want a VI's front panel visible and you can do that as I said from the VI Properties menu. Right click on the VI's icon or select it from the File menu. You can also set it with the VI Property Execution:Show Front Panel On Call.
