Vision Assistant Features to Front View
Hi all,
I want to Show the Vision Assitant Features like "Template Editor" in Front  View Panel . I am using Labview 12.
How can I achieve this?
Thanks.
(2,484 Views)
It is not possible to show the Vision Assistant as it is in its Configuration Mode while running the VI which contains the VAS.
However you could create your own Template Editor with the Functions provided by the Vision Development Module.
Another question is, why do you want to change the template during runtime?
Christian
(2,468 Views)
