Vision Builder's LabVIEW API example launches VBAI engine but Open Inspection button remains disabled.
I am using LV2020 64 bit. The LabVIEW API Example (local) is able to launch VBAI engine but it gives error code 354700.
This has happened for both Vision Builder 2018 and Vision Builder 2020. Can anyone suggest what to do?
(1,848 Views)
Hi akuljamwal,
In the error description you can see that the specified session cannot be found. I have checked all compatibilities and prove that they are compatible. Did you try to give as a constant VBAI interface without any cases which will contain the control, in input of Lunch Local VBAI interface vi?
Regards)
(1,789 Views)
Hi, the example program is working fine now. This seemed to be my system's problem. A reboot did the trick. Sorry to bother.
(1,766 Views)
