Vision Builder
hi to all,
     I  created a template with Vision builder and i want to check it with LABVIEW. If that template is correct with the scanned image then it will have to say "PASS" otherwise it will have to say "FAIL" . Kindly give an idea for this...........
(2,775 Views)
HI Tec-sol,
Are you using the Vision Builder for Automated Inspection?  If you are, then you can create LabVIEW code. In the configuration interface go to Tools>>Migrate Inspection to LabVIEW.  To do this you will need to have the Vision Development module installed.
Or are you using the Vision Builder?  Depending on the version of the vision builder you are using you can also generate LabVIEW code.
If you want your code to run in LabVIEW I would suggest that you create your code with the Vision Assistant (this has replaced the Vision Builder, and ships with the Vision Development Module).  The Vision Builder for Automated Inspection is intended to be a standalone application.  Where the Vision Assistant is intended to help you create your LabVIEW application.  I hope this helps.
Have a great day,
GG
(2,760 Views)
