Vision: Color of frame when moving ROI
I want to adjust the color of an ROI, when it is moved by the user. Normally it will be white, but I want a more visible color, like red: (it's a b/w picture, where you don't see the roi during moving).
TIA
Peter
(2,501 Views)
the ROI color can be changed in the image property node. use an event structure to detect when user moves the ROI for example.
(2,501 Views)
