Vision Run-time Activation
How many PCs can be activated with a single Vision 8.5 Run-Time License?
(2,916 Views)
Hi ST1,
Good Evening and I hope your well today, thanks for the post.
Application deployment with the Vision Development Module is based on single-seat licensing. This means that an individual license is purchased and activated for each deployment of your Vision application. The Vision Run-Time Engine is universally used to execute the application, but methods of deployment and available packages differ between versions of NI Vision.
When the Vision 8.0 (and later) Run-Time Engine is installed on the target computer, it must be fully activated or else it will default to Evaluation mode for 30 days.
I hope this answers you question, but I'd be more than happy to discuss this if you still have any other questions.
Thanks again for the post,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(2,895 Views)
