Vision and Packed Library - Incorrectly claimed items
Hi. I'm trying to create a packed library with some Vision VIs, however, when I put a Vision VI like "IMAQ Create.vi" into the library I got a conflict issue. In the packed library it seems there is nothing wrong, however, when I try to use the packed library in another project I got "Item incorrectly claimed by a library". Despite that, in the development environment, my application works fine, even when I use VIs that are part of the packed library, however when I try to execute some tasks like creating an executable or an installer LabVIEW stops to work and shuts down. I got some tests excluding the vision VIs and everything was fine. So, anyone knows what could be happening? Has anyone already used Vison VIs in packed libraries?
(1,778 Views)
What, exactly, do you mean by "when I put a Vision VI like "IMAQ Create.vi" into the library"?
Bill
CLD
(Mid-Level minion.)
(1,742 Views)
Sorry. I will describe it better. My library calls some vision functions. A project that uses the packed library got some issues regarding the warning "Items incorrectly claimed by a library". To track the issue I removed those functions from the library and, after that, the warning  was just gone. When I put them back, the warning comes back.
(1,729 Views)
Hmmm, I'm not super-acquainted with packed libraries, but I imagine if you include dependencies with your library, you may end up with this issue.  Anyone else have ideas?
Bill
CLD
(Mid-Level minion.)
(1,717 Views)
