Vision assistant features
I was wondering if someone could tell me how to modify an image´s brightness, contrast and histogram with the vision assistant. I want to do this, so I can normalize the image and reduce the impact that the external light has on the image. The system I´m developing will always have illumination, but I don´t want the results to change so dramatically with just a little change in illumination.
Can someone please help me?
Thanks in advance!
Message 1 of 9
(5,115 Views)
Accepted by topic author Nando88
There is direct function under image - brightness.  You can adjust brightness, contrast and gamma. If you want to go dynamic check lookup table
Message 2 of 9
(5,104 Views)
Is there something I could do to adjust the histogram of the image, to normalize the image a little more?
Always using the vision assistant.
Message 3 of 9
(5,100 Views)
In vision assistant you can play with the look up table functions.  In labview you can implement certain normalization functions
Message 4 of 9
(5,094 Views)
Is there anything else I could do to normalize the image?
Message 5 of 9
(5,082 Views)
How do you want to normalize the image? For example using histogram value or correlation of intesity values? Please give some details
Message 6 of 9
(5,062 Views)
I tried what you told me before, and it worked great, but I think I can still get better results. I used the brightness, contrast, color plane extraction and lookup table. How can I use histogram and correlation?
Thanks in advance.
Message 7 of 9
(5,048 Views)
I tried using histogram, and nothing happened. I tried both options, but nothing happened. The other thing is that I can't find correlation anywhere. Can you please tell me where I can find this option in the vision assistant?
Thanks!
Message 8 of 9
(5,038 Views)
I have tried something similar.  I will post that once I get to my pc
Message 9 of 9
(5,031 Views)
