Vision software sending UDP packets on port 3956
When LabVIEW loads the vision module it starts sending UDP packets on port 3956.  I understand that these packets are being broadcast in order to find GigE cameras, however there is a function in LabVIEW to poll for GigE cameras so why is it constantly polling?  I am querying this because our company network administrator is unhappy that machines are broadcasting UDP packets.  I know they are 16bytes and only every few second, but Im not the network administrator!!
Thanks for your help,
Tom
Message 1 of 9
(9,185 Views)
Hi Tom,
Are the UDP packets always on port 3956? When you say LabVIEW loads the Vision module do mean during the start up of LabVIEW or when you load a VI that uses Vision or something like the Vision Assistant? How are you monitoring the UDP packets?
Regards
Jon Bowers
Applications Eingineer
NI UK & Ireland
Message 2 of 9
(9,169 Views)
Hi Jon,
It would appear that the packets are only on port 3956.  Also they only occur when a VI using the vision module is loaded.  The packets have been monitored using WireShark
Tom
Message 3 of 9
(9,164 Views)
Hi again Tom,
could you send me a copy of the VI you are using so I can test it here. Is it when you run the VI or when it is loaded into memory?
Regards
Jon Bowers
NI UK & Ireland
Message 4 of 9
(9,158 Views)
Did you find a solution to this?  We are having the same issue, and our Network admin is not too happy as well.
Message 5 of 9
(7,886 Views)
Greetings,
                I am an admin and I can tell you I'm not happy about that at all.  It should not be a default behavior.  I don't know any admin that would want their network flooded with packets like that.
Message 6 of 9
(7,841 Views)
@cpcadmin wrote:
Greetings,
If the statement above is correct that the packet is only broadcast every few seconds this is hardly flooding th enetwork. Any Windows PC spews lots more junk than that. While I agree that there should be a way to disable the broadcast packets as an admin I would not be too bothered by a device sending a packet every few seconds. My PC sitting idle sent 181 packets in 11 seconds. Three or four UDP broadcasts added to this is certainly not that significant.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 7 of 9
(7,832 Views)
It is as exactly as you said. Every PC/device is sending unicasts and broadcasts.  It's their combined numbers that can make it a problem.  I'm disappointed when I see a device's default behavoir set to broadcast, I get more concerned the more devices I have on my LAN that act that way.  IPv6 will help but we are not yet ready for that internally. I"m guessing most aren't either.
Nice tag BTW,  One of my guilty pleasures.
Message 8 of 9
(7,828 Views)
Sailing or boating? I race sailboats on Lake Michigan. I crew for a 42' boat.
Mark Yedinak
LabVIEW Champion
Message 9 of 9
(7,824 Views)
