Vision utilities
Hi everyone,
i'm using labview 8.5 and i need to extract a single plane colour from a rgb 32 bit original image; so i used extract single plane colour from vision utilities creatina Also a constant to control the colour plane to extract, but it didn't work beacause i always see the original image on my screen with no distinction between green or red or blue. Is there Anyone Who had the same problem? How did you solve it?
Thanks for your answers.
(2,744 Views)
If i understand your problem, you want manipulate a RGB image to show the different colour planes. To help you in your application, send the following link to an example. This code has been supplid with two image files to aid how to show this.
https://decibel.ni.com/content/docs/DOC-5655
(2,693 Views)
