Vision
We have a 16-bit image and trying to process that image using Vision module LabVIEW 2010. Is 16-bit image possible to process in Vision toolkit ?
We are buying Biomedical Toolkit for LabVIEW 2014, We are not aware of processing 16-bit images in that toolkit.
When I am opening and saving the 16-bit tiff image, intensity values of image are varied 10 times of original image intensity ( example: from 3,200 to 35,000). Why it is happening. I have attached screen shots of small code and inverse help context.
(3,580 Views)
Following image files are the reference for this question. In this you can absorb the intensity (pixel values) variation after open and save 8bit image in Labview.
(3,528 Views)
Following image files are the reference for this question. In this you can absorb the intensity (pixel values) variation after open and save 16bit image in Labview.
(3,526 Views)
