VisionDevMod: Checking for a valid image
The question is simple: How to check whether an image wire carries a valid image? Valid meaning the value on the wire points to a piece of memory that has been properly allocated with IMAQ Create.
In the past I've been using just a comparison to simple image constant. This turns out to go awry whenever a once valid image (carrying a name) has been disposed of by IMAQ Dispose.
After I realized this I turned to use Not A Number/Path/Refnum.This works perfectly so far, as is suggested to behave as such in this discussion from a while ago:
LAVA.org: check-image-input-is-valid/
The following snippet illustrates this behaviour:
In later programming tasks I have come across the problem with "empty array fillers" in 2D-arrays of images - If several different-sized 1D arrays are built into a 2D array, empty filler elements are created in the "shorter" rows. Now - if I want to check, how many valid images are held within one particular row, I thought, well, "Not a Refnum?" works for this - let's use "Not a Refnum Constant" with "Search 1D Array".
But no, images and "Not a Refnum Constant" are not compatible.
I tried TypeCasting the "Not a Refnum" into an image: Broken wire.
I tried TypeCasting the "Not a Refnum" into a string (leaving the type connector empty) - same as when searching for an empty image constant (of course).
Now I use this little function which, however, seems a bit overkill:
Is there an "official" way NI endorses to do what I want. Or is there even a more obvious one I've missed?
Thanks for any enlightenment.
Falk aka comrade
(5,592 Views)
Accepted by topic author comrade
Hello Falk,
thank you for your request. The way you solved the issue seems to be well-programmed. Are you experiencing any drawbacks with the 'overkill' function you use at the moment? If it works fine, I would say you found a good solution already.
Best
Martin
(5,370 Views)
Alright then. I was just hoping for something similar to the Search 1D Array primitive. Case closed.
(5,364 Views)
