Visual Sourcesafe Link To Individual Projects
I use Visual Sourcesafe 8.0 when developing projects.  With the new feature in LV 8.5 a user can now assign a specific project in VSS to the current LV project.  This will allow for directl linking to the VSS project each time the LV project is opened.   Unfortunetly it appears that this feature is not working properly or I am doing something wrong.  Everytime I switch projects I receive the following error.
LabVIEW was unable to open the source control project for this LabVIEW project. The source control settings might not be valid for this session or a timeout occurred. Source control will not be available in this LabVIEW project.
Select Tools>>Source Control>>Configure Source Control or Project>>Properties  to reconfigure source control.
Additional Information:
Error -2902 occurred at SCC_Provider_Startup.vi.ProxyCaller
Possible reason(s):
LabVIEW:  An error occurred while opening the specified source control project. The source control provider does not recognize the project name. Verify that the project name and location are correct.
I then must solve this by opening the project properties window and retargeting the project specific source control settings under the Source Control category.
I am positive that I am saving the project correctly before checking the data in.  I am just confused why this feature doesn't seem to keep my settings.  Can anyone shed some light onto this situation?
Thanks in advance.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
Message 1 of 21
(5,558 Views)
Firstly I want to make sure what version of SourceSafe you have since as far as I know there is no 8.0 version of SourceSafe.
Secondly, the terminology is important since SourceSafe and LabVIEW have meaning for the term "project". So is this the scenario:
1. SourceSafe is configured in LabVIEW (via Tools>>Options) to use a certain VSS project.
2. You have a LabVIEW project where you have configured (via Project>>Properties) a specific VSS project to use.
3. When you say you "switch" projects, do you mean via Project>>Properties, when you attempty to change the associated VSS project you get an error?
George M
Message 2 of 21
(5,541 Views)
I apologize.  The actual name is VisualSourcesafe 2005 but it is version 8.0.5xxxx
No.  I am using the project properties menu.  Under the sourcecode control category I select Use project-specific source control settings.
yes.  I have multiple projects that have this configured for different VSS projects.
No I physically close LV project A and open LV project B.  LV Project B has a different VSS project than LV Project A.  I do no changing of the project properties when performing this.  Also if I were to close LV project B then and open LV Project A I get the same error.
Hopefully this might clarify I am assuming that this is not a VSS problem but I am open to any suggestions.  The obvious work around is to target the project again using the project properties menu each time I open the project but I don't think that is what was intended.
BJD1613
Philips Respironics
Message 3 of 21
(5,530 Views)
PS.  I am also making sure after I target the VSS project in the project properties page that I save the LV project with the changes that I just made and then check it in to VSS.
thanks
BJD1613
Philips Respironics
Message 4 of 21
(5,528 Views)
Here is a KnowledgeBase article that may fix the problem you are seeing. Are you receiving error 2976 or a different error? A screenshot of the error you are seeing will also be helpful in troubleshooting this issue.
Amanda Howard
Americas Services and Support Recruiting Manager
Message 5 of 21
(5,506 Views)
I am actually getting Error -2902. This is the text from the error window: LabVIEW was unable to open the source control project for this LabVIEW project. The source control settings might not be valid for this session or a timeout occurred. Source control will not be available in this LabVIEW project. Select Tools>>Source Control>>Configure Source Control or Project>>Properties to reconfigure source control. Additional Information: Error -2902 occurred at SCC_Provider_Startup.vi.ProxyCaller Possible reason(s): LabVIEW: An error occurred while opening the specified source control project. The source control provider does not recognize the project name. Verify that the project name and location are correct. Do you have an updated knowledge base article for VSS 2005? In 2005 these options are not available.
BJD1613
Philips Respironics
Message 6 of 21
(5,490 Views)
here are the windows.
BJD1613
Philips Respironics
Message 7 of 21
(5,484 Views)
Here are a few KnowledgeBase articles that might help troubleshoot the error you are seeing. [links removed; articles no longer available]
Problems Creating a Project with Visual SourceSafe in LabVIEW
Using Source Control Software with LabVIEW
Error 255xx using MS Visual SourceSafe 6.0 with LabVIEW Source Code Control
Amanda Howard
Message 8 of 21
(5,460 Views)
Hi BJD,
AFAIK, VSS 6.0 was the last released version released. Smiley Happy
Does this version really exist... ?! Smiley Indifferent
- Partha ( CLD until Oct 2027 🙂 )
Message 9 of 21
(5,443 Views)
I vaguely remember there being an issue regarding the use of passwords and SourceSafe. You wouldn't happen to have a user account that has a password?
George M
Message 10 of 21
(5,400 Views)
