Viterbi decoder
I'm looking for a viterbi decoder (for labview 6.1)
Could you help me ?
Jerome
(4,442 Views)
Jerome,
I was able to find only two documents on ni.com about viterbi decoder.
Superorthogonal Codes: A Near-Optimal Class of Codes for Spread Spectrum Systems
Capacity Improvement in the Uplink for a Cellular CDMA System using Successive Interference Cancellation
They may be in the editing stage right now, so in case the links to not work, the content of the pages is in the zip file.
Zvezdana S.
(4,442 Views)
Hello
Take a look at this link. There is a viterbi decoder in trellis.llb.
http://www.ece.utexas.edu/~rheath/research/mimo/labview/MIMOtoolkit.php
Hope this helps.
Alipio
"Qod natura non dat, Salmantica non praestat"
(4,442 Views)
