Vitesse d'aquisition
Is it possible to get a 1kHz  frequency  of data  with help of real time and compactrio only thanks beforehand
(3,048 Views)
probably not,
the cRIO is a chassis to put measurement and other stuff into it, without any of these you wouldnt have data input for the crio to process
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,044 Views)
I hurt my question I wanted to know if my while loop can give me values at a frequency of 1kHz example if I can have 300 points in 3 seconds and if so how? thank you for your answer.
(3,037 Views)
have a look at the timed loop structure https://zone.ni.com/reference/en-XX/help/371361L-01/glang/timed_loop/
btw: 1kHz == 1000Hz == 1000 samples per second
(3,034 Views)
