Voice Control through LabVIEW pinouts
Hello everyone,
I'm working on a Voice Controlled Robot which I will be utilizing LabVIEW as well as .net in order to implement the Voice Recognition System. I'm getting a list of commands ready to implement. Does anyone know whether I will need 1 pin per command on the DAQ? or how does this work. My thinking was that I'll will need 1 pin on the DAQ sent to an arduino which in turn will go to my motor controller (Sabertooth 2x25), this is turn will operate my motors for the appropriate command. Has anyone done anything similar to this?
Thanks!
(3,201 Views)
Ok, what?
We need a LOT more informaiton on your system to be able to come even close to answering.  What does the arduino have to do with anything?  How are you doing processing and where and how is your system supposed to look like......
You've given some information but absolutely nothing which would allow anyone to make anything other than a wild guess as to what you might need.
Spoiler
So if that's what you want:
Marmot.  I reckon Marmot is the answer.
Shane.
(3,178 Views)
@EMET_ENGR wrote:
Hello everyone,
Thanks!
.net to LabVIEW to DAQ to Arduino to Motor Controller - Did you just decide to use every piece of equipment on your desk?! Smiley Wink
As Intaris has said, you haven't given us nearly enough detail, but I would say that this is several layers of complexity too many. Why not simply communicate with the Arduino directly using the LIFA toolkit or serially? This is a much better solution than sending digiatl lines high on a DAQ to send messages.
-CC
"If anyone needs me, I'll be in the Angry Dome!"
(3,136 Views)
