Voice Recognition and Win7
I have used program Voice Recognition https://decibel.ni.com/content/docs/DOC-36514 , it works great! But it works only when the Voice Recognition function of the operating system Windows ON, this program can work without using Windows Voice Recognition ON? Windows pulls a bunch of garbage , and not my voice commands ! Thank you!
Message 1 of 8
(4,082 Views)
I also tried the VI on my computer, and I'm experiencing the same behavior.
There's another fairly active forum on voice recognition that may provide more information:
http://forums.ni.com/t5/Signal-Generators/Hello-I-Want-Labview-Control-An-Indicator-By-Voice-Recogni...
Best,
Brittany V
Message 2 of 8
(4,019 Views)
Hello
this program can work without Win7 voice recognition ON. It is SDK5 helper prog. May be we can atach it to Vi?
( i can not atach it, folder sdk Samples CPP SimplDict )
(SDK5.1  Bin SimplDict)
Message 3 of 8
(3,950 Views)
Sounds like you found a solution! If you have further questions on this example, I would suggest contacting the developer of the example, since they probably have a deeper knowledge of the subject. Their contact information is provided on the community example page.
GiantDeathRobot
William R.
Message 4 of 8
(3,901 Views)
This program is C++
Message 5 of 8
(3,886 Views)
You can access C/C++ files in a VI by wrapping them in a DLL. There is a tutorial on that here: https://decibel.ni.com/content/docs/DOC-9078
Also, it is not clear what SDK you are talking about. I think you mean the Microsoft Speech SDK 5.1?
GiantDeathRobot
William R.
Message 6 of 8
(3,837 Views)
Yes  It is SDK5.1  .
Message 7 of 8
(3,828 Views)
Ok. The tutorial I posted above should get you started with wrapping a DLL.
I also found this community example that uses Microsoft Speech SDK 5.1, which might help.
https://decibel.ni.com/content/docs/DOC-4477
GiantDeathRobot
William R.
Message 8 of 8
(3,793 Views)
