Voice Recognition and Windows 7
Hello Experts,
I read few posts about using voice recognition and LabVIEW. I must admit this is my first shot at such a project. My VI is already ready and works. All I want to do is activate my start button from my voice. Do you think this is possible this LabVIEW?
I have read through 5 post when I search for voice recognition and windows 7 but it seems very confusing to me. Can someone summarize the steps for me?
Thank you in advance.
(4,056 Views)
Maybe what you should really consider doing is gesture recognition. Smiley Wink
Voice recognition requires some sort of external program. LabVIEW in and of itself cannot do voice recognition - it's just a programming language. I don't know what posts you are referring to, but in the other thread where you posted a response jcarmody pointed out LVSpeak. Did you try that?
(4,040 Views)
I saw the video about LVSpeak on link below
https://decibel.ni.com/content/groups/labview-apis/blog/2009/11/19/labview-speak--programming-lv-thr...
I think its a great add on LabVIEW for visual programming. I will message the author but it isn't designed to activate some buttons when the program is running. I need the functionality close to that mentioned in gesture recognition link. But I don't I can get a Xbox or sophisticated camera tracking system.
I thought Labview could use Windows' speech recognition capability to perform voice recognition. The below link shows in windows vista. I was hoping something would help me to do this in Windows 7
http://www.ni.com/swf/flv/labview/us/vista/vr/
(4,031 Views)
I've seen that video before, though I never did find the VIs they used. That code is based on simply using .NET (specifically the System.Speech.Recognition namespace) as the interface between LabVIEW and the operating system's built-in speech recognition. Windows 7 has the same thing, so those same VIs should work in Windows 7. Maybe you can contact NI directly to see if they can provide the VIs.
A community example to use the System.Speech.Recognition classes can be found here: https://decibel.ni.com/content/docs/DOC-6865
(4,000 Views)
Thnaks for the link 🙂
(3,998 Views)
