Voice scrambler
Hello !
I want to create a voice scrambler. Something basic. I thought about different possibilities:
- Reverse the signal
- Change the frequency
- Add a signal (perhaps even the same signal but with another frequency)
Do you have any advice ? Could you perhaps give me tipps ?
If you have already done something like that, I'm really interested to know.
Have a nice day,
Maïwenn
(4,305 Views)
Well it simplest form of scrambling you take a bit stream and XOR a repeating "key". The longer the key the stronger the encryption.
Descramble is the reverse, XOR the key with the encrypted data stream and the output will be the original data.
=== Engineer Ambiguously ===
(4,263 Views)
Here's something I did a while back to encrypt/decrypt as file using the method above as an example.
You might be able adapt it to scramble digitized voice too.
(4,259 Views)
Thank you very much !
(4,209 Views)
