Voice signal to bits
Hello.
I have a problem. I want to modulate a voice signal (WAV format) in 8PSK modulation. My problem is that I want to take the voice signal to a bit stream, having it quantized in 256 levels, and I don't know how. I just get to receive the voice signal but I don't know how to start to get to this quantization and then to the bit stream.
Thank you very much.
Jose Rafael Monagas
Message 1 of 10
(4,168 Views)
you cant simply read your signal by the "sound file read.vi" and use the data output, which is a simple waveform (cluster) and do all your calculations on this cluster?
THINK G!! 😉
Using LabView 2010 and 2011 on Mac and Win
Programming in Microsoft Visual C++ (Win), XCode (Mac)
Message 2 of 10
(4,140 Views)
It is not what I am trying to do. I need to record the sound right there in the VI and then see how it is being modulated and demodulated. So I start with an analogic voice signal and have to do everything to have it modulated. which includes quantize it. This is where I have problems. I need to have it quantized to 256 levels.
Thank you very much anyways
Message 3 of 10
(4,129 Views)
I am sorry cschneider, I didn't understand well what you tried to say. I do now. I am trying to work with that waveform. It is what I was trying to do since I started the project. But my problem is that I don't know how to take that waveform all the way to a bit stream to modulate it PSK, and then demodulate it and try to listen to it again. My problem is really that I need to maintain as much information as I can so at the other side it keeps sounding alike.
I hope I can get suggestions or answers very soon because I am running out of time.
Message 4 of 10
(4,119 Views)
it will work like this for you? i am not familiar with your calculation, but this is a way, you can modify your waveform...
23194i0FB1405D3E94B0FA
THINK G!! 😉
Message 5 of 10
(4,105 Views)
This should be it. Then working with sound file data the range is +/- 1
23204iFBA383D3AD07C1B4
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 6 of 10
(4,084 Views)
I am sorry coq rouge I don't get your diagram very well.. where should I plug the sound waveform?
And cschneider, my problem is that at the end of the diagram I need to have a bit stream.. a 0,1 type of data..
thank you very much
Message 7 of 10
(4,076 Views)
Please look to the example from cschneider. Then replace the constant array with data from the sound card.
Message 8 of 10
(4,072 Views)
Hello. Good afternoon.
I have done what you recommended me. What you showed on the diagram. It works perfectly fine. Thank you very much. But I have another problem now, and it is that I don't know how to reverse the process at the other side of the mod-demod so I can play the sound waveform again.
Again thank you very much for your help Coq Rouge and cschneider.
Jose Rafel Monagas.
Message 9 of 10
(4,056 Views)
I do not mean to be rude, but I think I have given you a push in the correct direction, and to bring balance in the account it is time for you to present some code for further discussion. If you reverse engineer what I have done, and read up on AD/DA conversion it should be a breeze 😉
Message 10 of 10
(4,047 Views)
