Voltage Control for the Keithley 2450
I've been using the Keithley 2450 Source Meter to take resistance measurements. I know you can do a sweep to change the voltage and take measurements. Is there a way to manually change the voltage through LabVIEW, take a measurement and check to see if the target is met?
I'm using the Keithley 2450 library from Textronix.
(2,919 Views)
I would try Configure Output -> Enable Output -> Read (Single Point).
What have you tried so far?
(2,878 Views)
Did you try going to the Keithley website?
They have a LabVIEW library that you can download:
https://www.tek.com/source-measure-units/2450-software-10
Tim
GHSP
(2,869 Views)
