Voltage Pulse to RPM
@Marshman wrote:
Here is the code that I have started.
Check this modified code.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 11 of 16
(2,106 Views)
I will give this a shot and let you know of my results. Thanks
Message 12 of 16
(2,104 Views)
I tried it and it did seem to work decently. Although when I got below a certain RPM an error message kept popping up.  see picture.  How can I disable this, there are times when the rpm will be 0 but I want other tasks running within my bigger program.
Message 13 of 16
(2,094 Views)
What does 0 RPM look like to a program?  If I rotate one full revolution in an hour is my RPM 0.016?  Or do we just round to 0 and say we are moving too slow?  The program doesn't have a threshold for this.  You need to determine what is too low to measure and handle that appropriatly.  If it works out for you a simple solution might be to just make the RPM have a value of 0 if an error occured.  You can use a case structure or a Select function to use the calculated value or default to 0 if there is an error.
Message 14 of 16
(2,057 Views)
If I were to set RPM to 0 when an error occurred how would I set up the case structure to do this?
Message 15 of 16
(2,039 Views)
Wire the Error wire to the little question mark on the case structure.
Message 16 of 16
(2,030 Views)
