Voltage logging
Hello all,
I was wondering if anyone knows how I can create a voltage logger in Labview using the NI myDAQ. What I want the logger to do is measure the voltage say every 30 seconds or minute while inputing the data onto a graph so that I can display it.
If anyone one has any ideas then please tell me where I can get started.
Thank You!
(4,282 Views)
Hi naarchib,
There are resources on websites guide you on how to use myDAQ with LabVIEW.
I found one youtube video that might be useful for you
http://forums.ni.com/t5/LabVIEW/Voltage-logging/td-p/3048801
For timing, you might want to look at the link below to study more on how you can play around with timing function in LabVIEW
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/menus/categories/programming/timedlg-mnu.h...
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P82BSAS&l=en-US
https://www.ni.com/en/shop/labview/timing-and-synchronization-in-ni-labview.html
TuiTui
(4,262 Views)
Thank You! I will take a look at it.
EDIT:
Oh but I don't see the link to the youtube video?
(4,257 Views)
Sorry copy the wrong link
below is the link
http://www.youtube.com/watch?v=RsD2tHbuAF4
LabVIEW part should be around 2 mins in the video
TuiTui
(4,238 Views)
I'm pretty sure you can use DAQmx with the myDAQ.  Look through the examples in LabVIEW (Help->Find Examples) and do a search for Voltage Analog Input.  There should be a good example in there that will get you mostly to where you want to be.
(4,199 Views)
You can but not all of the myDAQ functionality can be used through DAQmx alone.  After installing the myDAQ software a special palette appears with myDAQ express VIs for doing stuff.
(4,154 Views)
