Voltage reading from a DAQBoard 2000
Two systems(win98 PC) with a DAQBoard 2000 per system. In labview, used the interface module to read voltages. With 4 voltages set to zero the output array reads [0.01mV, 1.5mV, 5.5mV, 10mV] channel 1-4 respectively. With no voltages conneted, same readings. Same problem with both systems. Questions: Should LabView be doing this? If so, what method do I use to read the voltages? If not, is there a new interface driver for the DAQBoard 2000? Note: I can't be charged for this. If you must charge, forget that I asked.
(2,891 Views)
I think you've posted this to the wrong place. If you need a new driver for an I/O Tech board, you should go to them. This forum is primarily for LabVIEW developers and is not the NI technical support line.
It's free this time but we may have to charge in the future.;)
(2,891 Views)
This is not a Labview issue but a hardware issue. As that board is not a NI board, you should contact the DAQ board vendor tech support.
Regards
Filipe
(2,891 Views)
