Voltage readings from transducer
Hi guys, I am currently stuck in here. I am doing a program that can take voltage readings from transducer using three-loop structure.
I have a layout for that in my front panel. I am not sure if I am on the right track. Can give me your opinions on this?
Many thanks!!!
Regards
Nic Ho
(3,925 Views)
The good news is that it appears that your program uses typedefs and queues, the bad news is that they aren't included so it won't load for me to look at.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,911 Views)
It appears that you are setting up a master-slave architecture, which is a good architecture to start with since it's flexible and easily modified. It's not clear what you're doing with those subVIs as they're not included, so I can't really make a comment on that.
(3,904 Views)
Hi, I have attached an updated version of my layout for my VI. Do let me know if you can't view the file.
Many thanks guys!!!
Regards
Nicholas Ho
(3,879 Views)
You should probably include the whole project in a zipped file. Next, you should describe what exactly you are trying to do, how your system is setup (hardware and setup), what architecture you are trying to setup and your thinking behind it.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,832 Views)
I get your point. What I am trying to do here is I first select a few channels. When the program is running, the total no of channels and the binary value
are displayed. By looking at the binary value, I am able to tell which channels are light on. Basically my objective is to get voltage readings from the transducer and save the data. However I like to do an "Initialise" before starting the program. In addition, I am looking on ways how to set timing for scan and data log for eg 0.5 hr, the panel will show this particular channel reading? U guys have any clues on this? Do let me know if you have problems viewing the file. Many thanks!!!
With Warmest Regards
Nic ho
(3,815 Views)
Hi everyone,
Hardware used:
SCX1-1000 hardware
Chassis: SCXI-1600
Terminal Blocks: SCXI -1322
(3,802 Views)
