Voltage regulator using labview interface for Arduino Uno
i am new to Labview so this question prabably sounds very easy..
i wish to create an GUI for a automatic voltage regulator.. the idea is like this: by keying in the level i want (ie: 100% for 5v, 50% for 2.5v), i can get the output voltage from the pwm pin from Arduino Uno.
but the problem is i am not sure which block to use (there are too many different type of pwm blocks in Arduino category) and i have no idea how the connection should be (everything i tried seems to have some error in it).
Is there any example related to this topic ? Or do you guys have any idea how to do this?
(3,568 Views)
Please post your query in a appropriate community in the forum. (Probably in this category Circuit Design Suite (Multisim, Ultiboard)
(3,381 Views)
