Voltage vs Current on a XY waveform
Hi there,
The main problem that I have is plotting Voltage vs Current from an external circuit connected to a Photovoltaic Cell (Solar Panel). Two voltages are measured in the external circuit and are fed into LabVIEW via a LabJack U12 interface card. The current is calculated in LabVIEW by simply dividing the voltage across a 1ohm sense resistor by the resistance. (Ohm's Law)
What I would like to achieve is to plot Voltage vs Current in a graph/chart if I vary the load resistance in the external circuitry connected to the interface card.
I have tried connecting the voltage and current in LabVIEW to a waveform chart via a "Bundle" function and "Cluster to Array" function. An output is produced on the waveform chart
, but not what I require.
Hope someone can help!! Please find my efforts in the attached LabVIEW version 6.1 file.
Thanks very much,
Neil.
(3,819 Views)
Hope the attachment file to be useful. In detail, you can read the example "Variable-time xy chart.vi" in the Labview software.
(3,819 Views)
Hi George,
Thanks very much for the prompt reply to my query. The file you attached did the job and helped me to progress.
Best Wishes,
Neil Sampson.
(3,819 Views)
Hi Neil,
find attached your .vi with some changes.
I typically use this kind of graph, because it allows
to append some sweeps (in my graph you will find, how
an accumulator was loaded with const. current vs time )
In case you select "single" ,the graph will be cleared.
For your other parameters you only need to copy the
accu vs time stuff.
I think, this gives some more ideas - how it might work.
One additional feature of my graph is - you can print it without wasting black color. How long does it take
until NI has learned how a graph should look like !!! ???
regards
Werner
(3,819 Views)
