Voltage vs. time
Hi I wanted some advice on what graph/chart to build. I have two voltage channels that I want as my two data points on Y-axis. Then for the X-axis I want the time in microseconds(or a similar value). Didn't know which option would be the best to display it.
Thank you so much
(5,941 Views)
Start with a chart, it depends more on how you want your interface to update.  Graphs are all at once and charts have a 'memory' that shows history.  If you are wanting to have voltage over time I would recommend using a waveform type with your data acquisition...  Are you using Daqmx?  If so it's pretty simple, your output will go straight into the chart.  It'll looks something like the attached.
(5,932 Views)
I'm using the DP821 instrument driver but I believe both should be similar in how they work?
(5,918 Views)
Might take a look at this for driver information if you don't already have it:
http://forums.ni.com/t5/Community-Documents/Rigol-DP832A-Instrument-Driver/ta-p/3512811
Looks like it works with all 800 series devices.  This might give you the driver side of it you'll need.
(5,904 Views)
I need a graph like that if the drawing helps any
(5,841 Views)
If your X (time) axis is in milliseconds I assume you're only collecting data for a couple seconds at most.  Therefore a waveform graph is the most appropriate choice.  Charts are for watching slower events occur in real-time.  You'll also find it easier to setup your time axis using a graph since it will read the dT from your waveform data.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(5,819 Views)
I think we can help better if you let us know what you've tried and what's not working about it. Where are you running into trouble with creating a graph like this?
(5,805 Views)
