Vst 5644R-problem with xilinx tools
Hi everyone,
I'm try to run the example of vst 5644r which is vst streaming. When i run the labview code under the target. I get this error:-
Labview fpga: the selected target requires 64-bit xilinx tools, but the system user a 32-bit Os.
Refer to the xilinx log report for more information or contact National Instrument technical support at ni.com/support.
Please anyone help me to figure out what the error means.
Thanks in advance
(4,043 Views)
Dear Iena14,
You have tried to compile a LV FPGA code with your OS. In order to compile your LV FPGA code, LabVIEW needs to use the Xilinx tools to get a binary for your FPGA. These tools are provided with the LabVIEW FPGA module but it seems you need a 64-bits OS. Try to check if National Instrument provide the 32-bit version of these tools or check for earlier versions (I remember to have compiled some FPGA binary with LV2012 version on a 32-bit OS).
Cordialement / Regards
Patrice NOUVEL
Project Leader
CLD
(3,955 Views)
Dear pnouvel,
Thanks for your answer.
May i know you have compile your LV FPGA code under the what target?
I have tried compile a LV FPGA code under flexrio target and it work. But when i uses vst5644, i get this error:-
Labview fpga: the selected target requires 64-bit xilinx tools, but the system uses a 32-bit Os.
Refer to the error, I also think i need to change the os to 64-bit since the vst5644 required 64-bit xilinx tools. But i need confirmation from anyone whose expert in this field.
Thanks in advance.
(3,909 Views)
