[W] Schedule Event
Schedule Event let you set event trigger time in advance.
No lock up.  No parellel loop.  No poll.  Reentrant.
Designed to work with the Event Structure.
Available for download at:
George Zou
(3,767 Views)
Very cool, however a quick note - LV 7.1 only - needs re-writing for LabVIEW 8 since the block diagram of the Schedule Event sub vi is not present, so it can't compile up.
// it takes almost no time to rate an answer Smiley Wink
(3,674 Views)
