WAGO 750-842, 4 - 20 mA current I/O
Hello!
I am preparing a simple test bench where I would like to measure temperature, pressure and control heater with current output.
I have WAGO 750-842 connected via ethernet cable. I have a modul for PT100 and PT1000 temp. sensors (750-461) and moduls for current IO (750-554, 750-454).
I can already measure the temperature, but now I am stuck at the point where I want to measure input current from a transducer. WAGO is running green, but all I keep on getting from the transducer is value of 8500. I am trying to operate current in 4 - 20 mA range.
I would appreciate some help regarding current I/O at LabView-WAGO.
Thanks.
Ziga
Message 1 of 1
(3,097 Views)
