05-30-2011 02:18 PM
Probe 37 will always be an empty array. With every start, it clears the array from the shift regsiter an places new data. Once data is acquired, you can save it. If you press clear, the data in the shift regsiter is again an empty array and there is nothing to save.
05-30-2011 02:18 PM
@gj;AKLDFJG wrote:
And one thing more I can save this data in what kind of formats?
You can save the data in any format you desire.
05-30-2011 08:11 PM
05-30-2011 08:17 PM
Sorry snapshot didn't got attached in last reply.
05-30-2011 08:55 PM
Ah, sorry, there is a small oversight. In the "clear" case structure, wire the array across in the false case and delete the array wire in the true case. All better?
05-31-2011 01:06 AM
hey it did worked, thanks a lot...
