WAVEFORM CONVERSION USING LABVIEW
HOW DO I CONVERT A PULSE WAVEFORM GENERATED FROM AN IR SENSOR USING MYDAQ TO DISPLAY A PQRST ECG WAVEFORM USING LABVIEW
ATTACHED BELOW IS THE PULSE WAVEFORM WE HAVE GENERATED AND WANT TO CHANGE.
(3,507 Views)
Hi subho,
so you're measuring a "square" pulse, but you want to display a "heart beat" ECG plot?
Either you have to fake your reading or you may use a sensor suited for this measurement task!
(3,486 Views)
Thanks for ur valuable advice sir,
but i did not post the question here for people having less knowledge in the field to ans.
if i had to fake it i would have,instead of asking here.
its advisable that u plz dont ans if u dont undrstnd the topic.
the doubt asked here is well valid and the conversion is possible,a ppg pulse waveform can be converted to a pqrs waveform with suitable algorithms nd processing techniques,only a little help is required but not suggestions to fake or change circuitry is entertained.
thanks,
regards subho
(3,420 Views)
Can you provide a link to these algorithms and attach your code where you are trying to implement them? Can't do much with just your vague description.
(3,405 Views)
You might look into the Bio-Medical toolkit or ask in the BioBench forum.  I'm with Gerd on this one though.  If you think you're going to generate a meaningful ECG from the pulses in your photo I hope your patients have their final affairs in order. Smiley Sad
Also, I suggest you avoid the use of that childish text-speak and take the time to write like an adult if you want to be taken seriously around here.  It's especially ironic considering your snobby attitude.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,386 Views)
