WHY THE TRACE STATICS TOOL IN LABVIEW DSC 8.5 GIVE THE FIRST ARRAY VALUES WRONG WHEN YOU USED MORE THAN ONCE IN A VI
IN LABVIEW DSC MODULE 8.5
WHEN I USE THE TRACE STATICS TOOL IN MY VI, IT WORKS OK (WHEN I ONLY HAVE 1 INSTANCE OF THE OBJECT)
BUT WHEN I USED MORE THAN 1 INSTANCE THE OBJECT SENDS ME A WRONG VALUE
IS THERE ANY FIX FOR THIS ERROR OR I MUST LIVE WITH IT RE ARRANGING MY ARRAYS FOREVER?
(2,396 Views)
Please post a small example that demonstrates this behaviour.
It sounds like there is a shift-register that is not being re-initialized or the VI should be set as "re-entrant".
Either way only NI can fix that situation and they will not fix what they don't know if broke.
A small example demo-ing the fialure will show them that this needs fixed.
Tryin to help,
Ben
(2,376 Views)
