WIN 7 STARTER AS A TARGET
Have used a netbook with XP before for target application and need to know if netbook with Win 7 starter will work.
Dg
(2,436 Views)
What do you mean by "target applications" ? Applications created by Labview? If so, you have to add a line to setup.ini file in order to have the application installed on Windows 7 Starter Edition.
[OS]
AllowWindowsStarter=1
(2,434 Views)
Yes, it will work just fine.
(The INI entry mentioned is only needed with older LabVIEW versions. What version do you have?)
(2,430 Views)
