WSDL Webservice with Windows 7
When i import a WSDL-Webservice on Win7 i get the following error-message, when i want to start the automatically generated VI:
Service1.Service1.GetSinglePartStatusHuHandling, (System.Reflection.TargetInvocationException: Ein Aufrufziel hat einen Ausnahmefehler verursacht.
               Inner Exception: System.Security.SecurityException: Fehler bei der Anforderung des Berechtigungstyps "System.Net.WebPermission, System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089".) <append><b>System.Security.SecurityException</b> in mit_Name.lvlib:Get Single Part Status Hu Handling.vi->Unbenannt 1
 When i do exactly the same on a Win-XP computer the automatically generated VIs run fine, also if i copy these under XP generated VIs and Librarys to the Windows 7 PC.
My question is, how can i solve the .Net System.Reflection.TargetInvocationException in Windows 7?
Thanks a lot in advance!
All the best!
Message 1 of 1
(2,635 Views)
