WT210 Reading from external sensor
I need help with using external sensor to read current in LabVIEW. Are there any examples? What I did was, from the "Measure Mode Value" example, I connect Config Ext Sensor Scaling. I don't know if it's right or not.
Any help would be very appreciated.
(3,361 Views)
What is a wt210? What example are you talking about?
(3,356 Views)
Sorry,
Yokogawa WT210 Digital Power Meter
(3,350 Views)
Accepted by topic author thnguyen24
You can compare the commands that are in the function to the command in the manual. I haven't used that instrument.
(3,348 Views)
I got it!
(3,332 Views)
