WTH is an I32 precision?
I was struggling with a bin value (Control) of 0.1 that my FP was refusing to register:
so I looked at the display format and changed it to show 2 digits of precision, like so:
Strangely enough, whatever I would enter 0.1, 0.01, it would always reset to 0...
Hmm...
Then I did something really stupid, which is to look at the "Representation" of my control and..tada! it turned out to be an I32  control.
I am asking: why am I actually capable of adjusting the display format of an I32 to show 2 digits of precision?
I mean what is the intent here, besides playing trick with the unsuspecting developer?
The Property "Format" tab for that type is exactly the same as for a float:
Tab and I get this:
After all, I guess an integer with 9 digits of precision is better than one with none:
Message 1 of 23
(4,321 Views)
That is advanced preparation for the fraction integer datatype which will be introduced in LV2547.
Lynn
Message 2 of 23
(4,319 Views)
I want to show DBLs in hex myself.
Message 3 of 23
(4,304 Views)
For the same reason that %d stands for decimal when formatting a string with a number which has no possiblity of having digits after the decimal Smiley Very Happy
disclaimer: I'm sure there is a valid reason for this
Message 4 of 23
(4,288 Views)
Actually, there is a very valid reason.  Decimal simply means base 10.  Just the same way that Binary means base 2, Octal means base 8, and Hexadecimal (often shortened to Hex) is base 16.  All of these are dealing with integers.  The %d, %b, %o, and %x have been around at least since C got started.  They have nothing to do with the English name of decimal point.
Plus, look at your string<->Number conversions.  You will see a Decimal String to Number and Number to Decimal String.  Those are just using the %d convension.
Message 5 of 23
(4,265 Views)
Lynn
That's just too funny.
Doug
"My only wish is that I am capable of learning each and every day until my last breath."
Message 6 of 23
(4,240 Views)
I actually took that seriously for a second and if you actually start from an I32 type and change it to DBL while in the Property Dialog window, you can get there:
Problem is, clicking on hexadecimal (or octal, or binary) doesn't register. The display is stuck wherever it was.
You have to close and reopen the dialog window to get what I think is natural, i.e. grayed out properties that do not make much sense for that type:
But I guess it makes some sense to display an integer with added precision after all ???
Message 7 of 23
(4,231 Views)
All decimal digits of an integer are zero. Why shouldn't you be able to display them if you want to?
Message 8 of 23
(4,216 Views)
It makes a bit more sense when you use the same specifiers with Fixed Point.  Although, I never understood the limitation of not being able to display "." as a true radix point.  I've yet to see an explaiation why 0d1.5 can be displayed "0b1.1"  where "." is the binary point but not an octal point of hexadecimal point
Spoiler
Almost evil of me to dangle so many cosmetic bugs in front on X isn't it?Smiley Wink
Message 9 of 23
(4,210 Views)
Wait. What?
All digits after the decimal point are zero.
Message 10 of 23
(4,198 Views)
