Wait On Asynchronous Call node takes too much time to return
Hello the forum,
in my application I run a VI using the Start Asynchronous Call node, then I call the Wait On Asynchronous Call node with no timeout (= -1).
I observe a delay of about 3 seconds between the moment the called VI stops running and the Wait On Asynchronous Call node returns.
Which could be the reason of this behaviour? Is there a way to lower this time?
Have a nice day
(2,501 Views)
Could  you please post a simplified example of the problem you are describing?
BTW. This is a trick question... by distilling your problem down to a simple example, you will probably realize the mistake you are making... and if not, we can point you in the right direction.
Former Certified LabVIEW Developer (CLD)
(2,468 Views)
Hello Frozen,
here you are the simplified exemple. In this case no strange behaviour is observed, the called VI returns as soon as the execution ends.
The application in which I noticed the problem it's pretty huge. Which is the component that manages the call to the VI? Is it the VI Server? If yes, can the behaviour be caused by the number of VIs the VI Server has to manage?
(2,432 Views)
If the called VI uses lots of VIs it could well be startup/shutdown that's delaying it. You could instead of waiting for it have it send an event with the result, then it can shut down as slowly as it pleases. 🙂
Qestit Systems
Certified-LabVIEW-Developer
(2,415 Views)
